More than one circuit on a breaker; what code, plz! | Page 2 | on ElectriciansForums
Discuss More than one circuit on a breaker; what code, plz! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
also, you have an unused way in that board. split the circuits and fit a 16A? fuse and carrier in the unused way.
so the board would be a 4 anyway unless the bathroom is fed from this board without any RCD protection and no supplementary bonding....then its a 2.....
weel ...looks like 4 at first glance....but its actually 3 coming in....the other one dips behind the neutral bar/block.......
If it's four then I'll buy it as a solution, if it's three then the breaker is too high a rating for a spur in 2.5mm IMHO :)
Edit: assuming 4 = 2xRFC :)
Reply to More than one circuit on a breaker; what code, plz! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
