More than one circuit on a breaker; what code, plz! | Page 4 | on ElectriciansForums
Discuss More than one circuit on a breaker; what code, plz! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Because that's how they were designed in the first place, they only become one circuit when they are placed into the common breaker.
would you list them as two circuits ? or one circuit with the most pessimistic value recorded
just asking out of interest not interested in entering the debate that is evolving
personaly i see it as a spur from a RFC and as such i would test as one circuit dead and live
IF (big IF) you were certifying it as such then you would list it as one circuit. As GaryM correctly points out that's what it is. The point I was trying to make (poorly it seems) is that it only becomes one circuit when connected at the breaker. It should still be dead tested individually as designed IMHO. Next question will be about recording R1+R2 I'm guessing ;)
so if extranious conductive parts in the bathroom for instance (pipework) are not given supplementary bonding in an installation being fed from a non RCD protected board thats not a 2 is it? and does the board feeding it not require improvement?...or at least put an RCD connection unit to feed the bathroom circuit/s....then the board becomes a 4.....
I disagree that you apply a specific code to the consumer unit based on circuit defects.
If circuits 1, 2, 3 and 4 lack RCD protection then that's what you note, not that the consumer unit lacks an RCD.
well theoreticaly there could be two R1&R2
if two radials left a CB and were of the same lenght " whistles "
LOL
the reality is i would list as one circuit no code and would never of dreamt of asking on a forum LOL and i would nt loose any sleep or hair over it
No difference with the spur originating at the origin or socket 6. Still the same 32A protective device and no problem.
think about the 13A fuse in the plug top, there's your overload protection for the spur.
13A+13A = 26A, assuming it's a double socket.
Reply to More than one circuit on a breaker; what code, plz! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
