More than one circuit on a breaker; what code, plz! | Page 3 | on ElectriciansForums
Discuss More than one circuit on a breaker; what code, plz! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
[FONT=Tahoma, Calibri, Verdana, Geneva, sans-serif]
so the board would be a 4 anyway unless the bathroom is fed from this board without any RCD protection and no supplementary bonding....then its a 2.....
[/FONT]
The board itself is a code 4 or 2 due to what the circuits supply?
I'd totally dismiss a PIR if I saw a comment like that on it.
In case it's not clear what I'm saying, (it's probably not). The difference is in the dead versus live testing. You SHOULD dead test as two circuits and live test as one.....that'll cause some more debate!
At what point does a single protective device supply 2 circuits, bearing in mind the definition of 'circuit'?
Edit - you posted clarity above as I was typing this.
Hi TQ
why would you test as two circuits for dead testing?
cheers
Just this
You consider a change from 2 to 1 circuit at somepoint.
Yes GaryM, if I was to consider the circumstances under which someone (who remains nameless) decided to put two separate circuits into one breaker, that's exactly how I would test it dead. Of course if it's say an RFC with spur then Zs etc would most likely be higher on the spur portion, but that would be derived from the live testing of the circuit (singular). Most likely this would be a temporary solution and at some point the expectation would be to separate them, hence I would test it accordingly.
Just for clarification, someone spurred off from the RFC at the breaker to install a socket in the kitchen (under the kitchen units) to feed the boiler, the pictures show the cable route. Cheers!
That's a defect for the circuit(s), not the board in general.
so if extranious conductive parts in the bathroom for instance (pipework) are not given supplementary bonding in an installation being fed from a non RCD protected board thats not a 2 is it? and does the board feeding it not require improvement?...or at least put an RCD connection unit to feed the bathroom circuit/s....then the board becomes a 4.....
Reply to More than one circuit on a breaker; what code, plz! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
