Moving CU | on ElectriciansForums
Discuss Moving CU in the UK Electrical Forum area at ElectriciansForums.net
Rappid
Wickford, Essex
Got to replace a CU and move it off the ground in a shop, would it be acceptable to mount the CU on the wall in the void between the ceiling and suspended ceiling
The only problem I can see are the meter tail being borderline 3 metres.
Thanks.
How do you do that thing of copying section of OP in a nice quote box??
Anyway.... Somehow, needing to get a ladder to access CU doesn't strike me as being particulary accessible.
Mount at height where someone can reach quickly in case of need.
click on reply with quote Tony at the bottom right of the post and ensure you writing is below the last quote shown
Reply to Moving CU in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
I am a landlord/owner of a flat. I am just about to spur off nearby sockets to provide the additional 24hr supply to new Dimplex Quantum storage...
