Multimeter Recommendations
I'd be always testing low ohms and high ohms with the IR tester
Voltage with 2 wire probe
Current with a clamp
Depends what you're testing. Normal electrical wiring then all the MFT functions are fine. Electronic engineering stuff, alarms, etc. then the resolution and accuracy you get with a good multimeter will be more appropriate.
your problem there is the range/s on your MFT. on continuity >199 ohms is O/L. on IR ranges anything under 0.1 Meg reads approx. 0. this is where the multimeter comes in, e.g. fire alarm eOL can be 2.2.K up to 6.8K. MFT no chance.
This one seems okay for what I need:
that's out of stock. see this Fluke.
he's got more than 10 available. I had a similar model. was brilliant. jus need to ensure the hold button isn't in play when taking a new reading.
I did find an ACT one used for £40.. But I would be tempted to get new leads. This one has come up for sale. But the Fluke seems a better buy. I have a battery tester by ACT that is really great.
RDB85,
Zada22,
