My 1st board on site advice | Page 4 | on ElectriciansForums
Discuss My 1st board on site advice in the UK Electrical Forum area at ElectriciansForums.net
London
Hello,
I have just competed my 1st consumer unit install on site. I would like some advice on how I may improve the quality/neatness.
All constructive criticism welcome
[ElectriciansForums.net] My 1st board on site advice
514.4.3 PEN conductor A PEN conductor shall, when insulated, be marked by one of the following methods:
(i) Green-and-yellow throughout its length with, in addition, blue markings at the terminations
(ii) Blue throughout its length, with green-and-yellow markings at the terminations.
There is no percentage requirement.
I'm certain that there is, or at least used to be. Won't have access to my BS7671 until the weekend though.
Have you looked at the Reg pertaining to identifying conductors by overmarking as opposed to the colour requirements for PEN conductors?
For me, if I were inspecting an existing installation.
It would be:
1) no comment, correctly identified PEN conductor,
2) code C3, incorrectly identified protective conductor, or
3) code C2, PEN conductor used in a consumer’s installation fed from a public supply.
If it were an Initial Verification, it would be: Fix that.
Do you code every earth fly lead fitted with a blue ring crimp the same way?
Would you code the cpc of circuit number 6 the same way if coloured cable markers have been used?
It would be:
Have you looked at the Reg pertaining to overmarking conductors as opposed to the colour requirements for PEN conductors?
Here’s the thing:
I am neither French or German, and I’m not working in either of those countries.
I’m English and I work in the UK, to UK Regulations.
I have been known to work abroad and to the Regulations that pertain to that country.
Then again I’ve worked abroad and used UK Regulations.
Only places I know of in the UK, which use non-UK Regulations are American Air Bases and quarters.
At the end of the day, you have a choice.
Comply with the Regs, or don’t comply with them.
You can easily remove the coloured ‘insulation’ from the ferrule, either before or after crimping.
So if you don’t remove it, you’ve chosen not to comply.
Here’s the thing:
If you cut the plastic bit off then you are modifying a product and using it in a manner other than in accordance with manufacturers instructions. So if you remove it you don't comply with regulations, to the same degree of ridiculous pettiness as thinking a ferrule is a cable marker in the first place.
Perhaps you could answer the question about whether you would code the use of standard red, blue and yellow crimps as a non-compliance?
Yes I would.
Again you can remove the insulation.
If you think, removing the insulation would fall foul of the Regulations, then don’t use insulated crimps and ferrules.
Again it’s all down to choice.
You choose to use a non-compliant product, no one is standing behind you holding a gun to your head.
Of course, you could use some heat shrink to cover the blue.
Someone needs to make a range of ferrules with clear plastic to reflect the conductor colour and come up with a ferrule size system that’s not based on colour.
Here’s the thing:
Being the french or german colour scheme is just something that has become standard world wide as they were the ones who began mass producing them.
Absolutely nothing to do with working to their regulations.
By removing it, you've breaking other regs of not following manufacturers instructions.
On a side note, you can buy them without the plastic collar for anyone wondering.
I'll email a couple of the guys that I know in the IET/BSI Technical Committee, I'll come back with a response. They could use a laugh.
If I'm wrong I'll hold my hands up to it.
Whilst your Emailing them about that, could you ask them whether BS 7288 sockets and FCUs being used for additional protection?
Reply to My 1st board on site advice in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
I’d say yes go for it.
