My "Line/Wago" Products experience...
The in-line ones are almost the same size as a crimp. Just push the cables in at either end, quick tug to make sure they are secure and away you go!
Problem I find with the lever connectors (apart from the bulkiness) is that the cables have to eneter from the same side which causes a bit of a cable 'kink' when using for in-line connection --- hence the simplicity of the new in-line connector ;-)
p.s. Im not on any commission for good reviews!
I didn't realise Line did in-line ones now. The look like a great alternative to crimps!
I think the wago type are great for use in the line/wago enclosures but I agree they are not so neat in consumer units etc.
Just came across these line pushfit connectors. Using wago at moment and didn't know anyone else did these. Is the quality as good as wago?
Also has anyone used the forum link to buy these? seems like they might be telling porkies about the discount? or maybe just not updated the was price. for example one connector they suggest I would get 50% off. But if I go to the normal shop, the price is already much lower than the stated was price. confused? I am.
Thanks.
Thanks.
Hello Omega
There are many posts by other members about LINE. See also:http://www.electriciansforums.co.uk/electrical-forum-general-electrical-forum/59596-wago.html .
Regarding pricing on the forumshop the site is based on rrp so discounts are relevant to that and all prices reflect the special deal we offer forum members. The other site is maintained separately and reflect the best prices we are currently able to offer the trade in general.
All our products are guaranteed for quality. Our supplier had some tooling issues with the 5 lever connector so currently have limited supply of these but where this is a problem we do supply wago instead (at our price).
We will also gladly send samples - please pm me your full contact/postal details.
Please let me know if you have any other questions.
Regards
LINE
thought it was me and my tired eyes with the 5 lever types. couldn't get the buggers to hold even after using a hammer.
the 2 i had , the cable clamp seemed as if it would not lift up to allow the cable to go under it. TBH, i not sure whether they were line or wago.
Ive been looking at these too, but keep putting it off. Will have to get some of these ordered!
Thanks for the review.
Try them mate, they are brilliant the time saved far outweighs the small extra expense and I for one would not be without them. just sorting out my next order for job starting next week.
just placed my orders (2), I note that your L324L are from 0.75mm flex size, that's ok for me at the moment as i still have stock of this size. However in the future i feel that 0.05 would be a little cheaper as we only use LED. I could probably run all of the lighting on bell wire. Will you be introducing a 0.05 mm version.
Did you mis-type the size? I assume you're after 0.5mm....
1shortcircuit,
Dan,
