Mystery Item thread.... What am i? | Page 5 | on ElectriciansForums
Discuss Mystery Item thread.... What am i? in the UK Electrical Forum area at ElectriciansForums.net
Darkwood
mystery device1.pngmystery device 2.png This is out of an old Russian lathe it has 4 contacts on it 2 x NC and 2 x NO it has a coil and on top it has a sealed oil filled reservoir.
What is its function!
Spoiler alert!!! Answer in post 9!!!
You were right the first time! It IS a starter, but why is it like it is? What's in the bottom box that operates the rheostat? Here's a picture of the motor, not sure that tells you very much but it's a 12hp Crompton Parkinson wound-rotor induction. If you only had a fixed rotor resistance instead of a nice 10-stud starter, you could pull the lever on the end to throw a shorting plug into the slipring connections once up to speed. But for this application it would take longer to get up to speed on a fixed resistance and anyhow there's no-one around up here to pull the lever. The man who just hit the start button is down in the pit getting ready to begin.
mather & platt brush lifters with shorting ring.
This isn't as refined as the Mather & Platt, it just has the manual shorting plug but no brush lifters. So with the automatic starter the brushgear stays permanently in circuit carrying the 20A or so of rotor current. The daily running time even in their heyday wasn't long so the brushes lasted well anyhow.
Judging by the double loop hard wearing thread and looking at its relatively good colour tones and mix id say its a post 2000 stool but difficult to nail the exact date due to that 1937-ish timer sat on top!
Ye Olde Venner type 'C' (or variant of same). They certainly came out in the late 20s although a quick peek in Sunco 1929 and 1936 shows them only with mercury contacts at that time although identical in other details. I'll go for a little bit later than DW and say 1939, because my hunch is they dropped that style soon after the war.
Been a while since ive seen one of these but thought id strip it out for your pleasure...................Manual StarDelta 1.jpgmanual StarDelta 2.jpgmanual StarDelta 3.png
Putting that manual touch to a Star/Delta Starter .... to note the O/L advice to set FLC of motor and it was a nice mechanical arrangement if you look at the wiring diagram shows the differing motor terminal arrangements of the out going connections than we are used to seeing nowadays.
Reply to Mystery Item thread.... What am i? in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Floor tiling 600x600 48m2 Hello, this is my first post here, but I have been doing some reading. I am going to be tiling the whole ground floor...
Spacebug
