- Joined
- Jan 21, 2011
- Messages
- 581
- Reaction score
- 34
customer currently has a 1 double socket spurred directly from the ring main 32AMCB (piggy backed)in 2.5mm cable directcly under the main consumer unit. He is wanting to add another socket. Note no spare ways in Consumer unit and no other sockets within room. RCD protection present
if the existing spur socket is turned into a fused spur (13amp fuse) then it would be possible to now add an additional socket
as the 2.5mm cable can now only draw a maximim 0f 13amps and is back fused by the cartridge fuse in the fused connection unit as with any fused spur addition
im sure my thinking is correct but you never know
many thanks.
many thanks.
