Neutral earth fault | Page 2 | on ElectriciansForums
Discuss Neutral earth fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Agreed apart from the few minutes remark.
That said I would rather test every socket upon energising
Ok, a few minutes is optimistic. I have just finished a complete rewire on a property, and to cross-connect as I said in my earlier post and test at every point, noting every reading, took less than 20 minutes.
What I'm getting at is that there is no excuse to miss out parts of essential testing on a new install.
It is the mangers that do not appreciate how long it takes to test correctly. Especially when you have a long run of these tests to do. For example a 3 bed flat has over 60 socket (individual modules) on current project. That in itself will take longer than the whole of the remaining test. So that is 120 tests just for the sockets!
You will still need to test live at every socket, so IMO, doing it live will in effect will get a lot more results, and is a considerable time saver.
Energising and then live testing would be O.k , but not good practice, if there is no-one else likely to be put at risk of using an incorrectly wired socket or appliance and there is no risk of fire etc.
So the flat / house would have to be empty and secure.
Energising and then live testing would be O.k if there is no-one else likely to be put at risk of using an incorrectly wired socket or appliance and there is no risk of fire etc.
If the 'said' socket was used after energising then the RCBO would trip (given that the load was >30Ma).
That said when I live test, there is a permit to work in place!
Just to make clear, incase anyone reading this didn't know, a Martindale socket tester will not pick up a neutral/earth crossed connection which is why the correct dead tests are so important.
I always carry out the sequence of tests in the order I was taught at college, I do a Ze test before starting the design for a new installation, all the rest of my live testing is done after all the dead testing has been done. I only do new installations though so that is why I don't rely on Zs testing, I just use calculation.
I was never 'taught' to do R1Rn
Indeed I am struggling to find any reference for this
Certainly not in NICEIC Inspection, Testing and Certification, not in BS7671
If it is BS7671, I would like to know where
Reply to Neutral earth fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Very technical :D
2 3
