Neutrals in light switch | Page 2 | on ElectriciansForums
Discuss Neutrals in light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This was a grey area many years ago, from memory my old college tutors and sparkies, said never have neutrals in back of switch box, have done it myself a few times.If I did a job and it got knocked back I would fit a 20amp dp switch.:D
Nothing against a neutral in the switch back box, but only as and when it's required. Looping a complete circuit through switch boxes is another matter altogether!
images
Just for you 7029Dave. I'm sure you can figure them out mate.
push in for solid or stranded cables e.g. 1.5mm, 2.5mm. lever type for flexes. just bear in mind that they're not like choc blocks where you fit L,N, and E in. they're called 2 pole, 3 pole etc., but should be called 2 port etc.
Reply to Neutrals in light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
You were correct those are neutral wires, it worked! Many thanks
