Neutrals in light switch | Page 3 | on ElectriciansForums
Discuss Neutrals in light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
starts getting expensive when wiring 3 phase , 5 wagos thats about 2 quid 5 bits of connector block 50p
Nothing against a neutral in the switch back box, but only as and when it's required. Looping a complete circuit through switch boxes is another matter altogether!
Presumably you also have nothing against looping a perm live through a 3 plate light as long as it's required......oh,it isn't though is it?....:D
if assesor wants to be pain then get some self adhesive cable tie mounts (toolstation stocks it),
fix them into boxes using a screw each and hold the wires with a cable tie.
Before sliced bread what was the best thing?
Beer? Cheese?
I would say those two are much better than sliced bread, in fact sliced bread is pretty rubbish in comparison.
I think 'the best thing since sliced bread' relates to 'the best thing in recent times' rather than 'the best thing ever', otherwise people would compare things to 'the best thing since beer'.
But the assessor asked for the neutrals to be fixed to back box. Wago won't achieve this!
In accordance with which reg?
The lives aren't fixed to the backbox either, the terminals in the switch are fixed to the switchplate, not the backbox. Until you screw the plate back they're in a similar predicament to neutrals in a bit of terminal block or a wago.
The reason cpcs are terminated in the backbox is to earth the backbox, not because they need to be secured; if I were terminating cpcs in a plastic backbox with a plastic switchplate I'd have no problem terminating those in a bit of connector block or wago as well.
As mentioned, I couldn't think of a reg that prohibited a neutral in a switch box. The point made about fixing to cable tie base is a valid one at least the neutrals are attached to a fixed point. As also mentioned I think the schemes like to think up these things so they can at least pick us up on something in our assessments!
got it in one! BS7671 rewritten by scam providers.
Reply to Neutrals in light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
You were correct those are neutral wires, it worked! Many thanks
