NEW circuits into non amm3 DB. ????? | on ElectriciansForums
Discuss NEW circuits into non amm3 DB. ????? in the UK Electrical Forum area at ElectriciansForums.net
saddleworth
If I was to wire an extension on a house , and the DB does not meet amendment 3 , where do I stand adding new circuits into this DB , is it ok or should it be changed to Amm 3 DB
Know I should know the answer to this but hey ho were not all perfect
no problem in connecting new work into a non-metal CU. i would, however, check all connections in it for tightness.
what do YOU think?
My thoughts are it would be ok , now before you all jump down my throat , I only really work on industrial etc so not used to dealing with domestic dwellings and local authorities part p , part f etc
So not 100% on this hence the thread
So I await the vultures and keyboard warriors to attack me and my imcompatance , LOL
So I await the vultures and keyboard warriors to attack me and my imcompetence , LOL
Matey, take a tip, offer your answer and answer questions put to you, then when done give feedback and thanks....
AMD 3 came out nearly 3 years ago ........... I find it tricky to believe that ANYONE who claims to work in the industry doesn't know the answer to this.
that's him told off by head master Murdoch, is that 50 lashings for not keeping up with the regs .
I meet sparks regulary that wouldn't know the answer. . . . .
AMD 3 came out nearly 3 years ago ........... I find it tricky to believe that ANYONE who claims to work in the industry doesn't know the answer to this.[/QUOTE
expected this response, which I don’t mind ( big shoulders ) , yes I just wanted to confirm my thoughts
But cheers guys thanks for the reply’s
Do I consider my self told off for posting the thread
I must add to this thread , when having an extension on residential properties , fire and spread of fire is a major part of the building regs , smoke’s , fire doors , escape routes
So why not introduce ammendmant 3 into this if you are adding new circuits onto an existing DB
Good idea or not ????
I won’t ask you my next question about wiring in wet string then regards latest regs
Reply to NEW circuits into non amm3 DB. ????? in the UK Electrical Forum area at ElectriciansForums.net
And fully tested it with an MFT obviously
