Our house is less than 2 years old. Gas is bonded in 10mm, no bonding to water. Although the original EIC issued indicates there is bonding to Gas AND Water added to this there is 2 bonding 10mm cables in the CU one definitely goes to Gas (visual and continuity) to this day I haven't found the end of the other 10mm. The water main comes in under the sink in plastic, changes to copper to sink taps and washer and dish washer taps, combi etc then there is plastic to go up stairs to 2 x bathrooms and to airing cupboard with a pressurised hot water system, as well as a downstairs toilet. All change back to copper for the last couple of foot before taps. Heating system is all plastic direct to the rads.
Yeh I do agree. If its entirely copper then more than likely it needs it.
Do you see what I mean though, if people are taught to test and see then people would know what needs it and doesn't.
Otherwise we could see people bonding
Anything metal just in case......
And that's just wrong
And no, I'm not an advocate of the "bond anything metal" mentallity :mellow:
we are commented on OP situation here where he has all copper install plastic incomming and yes i do understand about the testing part and getting ppl to understand when and where but regarding the OP situe id have bonded it regardless of reading, if it was part mixture copper and plastic throughout then id go by the result of the resistance test and see if it likely to remain that way in hindsight.
As an apprentice I was taught how to test an installation (Although it took a while for me to understand the whys and wherefores) because, in Bill's words, any self respecting spark should be able to prove his work is safe. I completely agree with that.
Nowadays sadly it seems to happen more and more that sparks will say I don't know how to test or what the results mean and this is on all types of installation. It makes me bloody annoyed, how can you call yourself a spark if you cannot completely finish the job by testing it and filling in the cert, or find a fault
Gotta agree their Trev .... my theory is a monkey can pick a cable size by rule of thumb but an electrician can explain indepth to why its done that way and what the test results stand for, both will walk of site feeling like they know what their doing but only the monkey is kidding himself.
Going back to the op, if there was an earth potential being brought in it would be from the gas incomer which is bonded, if there is an immersion heater the pipework would have a connection through the cpc of the heater element, i believe also that if IR tested and the reading between the MET and the pipework is less than 0.05 ohms and the water incomer is plastic then there is no need to bond as a good connection is present. If the water incomer was metal then bond it as, in the future, the gas could be brought in as plastic and the bonding disconnected.
New house, no main water bonding
ash_s3,
jumpin jax,
TrueNAS JBOD Storage Server
