View the thread, titled "Newly Qualified to domestic level" which is posted in Domestic Electrician Forum on Electricians Forums.
Need to spk with someone i re did the shower r1 r2 test got 0.01 ohms to begin with and got a green X then trying it again i jave gone straight bk to a red X wracking my brains on this one very strange have nulled the leads but getting very mad results lol
As been advised, check connections, check batteries. Unless the testers u/s, you should get the same (or very similar) test results.
Plus not knowing the meter (but think I understand the concept), 0.01 ohms gets a green X pass but the readings too low and 0.21 ohms gets a red X, fail on both counts. :)
With metrel you can set a fail level for continuity. On mine it's default is 2 ohms. Often get a red X when testing continuity of long lighting runs but that's just because I can't be bothered to adjust the limit. I don't look at the X, it's meaningless so long as you know what figures you should be looking for
Reply to the thread, titled "Newly Qualified to domestic level" which is posted in Domestic Electrician Forum on Electricians Forums.
