No cpc on lighting and no neutral continuity on kitchen ring | Page 3 | on ElectriciansForums
Discuss No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
Buckinghamshire
Hi All,
I recently replaced an old rewirable fuse board for metal split load rcd board. However on testing prior to replacement I noted that one of the lighting circuits doesn’t have a cpc. I’ve put this in the EIC for the new board that no cpc for lights, advised client that needs rewiring and advise against metal fittings accessories etc,is this the right course of action to take? They do already have metal fittings on this circuit, Is rcd protection enough to cover this? Also the kitchen ring has no continuity on the neutral conductor, I’ve had all the accessories off to find it but can’t, I’m assuming the break maybe in a buried joint box as the kitchen is an old extension. What’s the best course of action to take regarding this please?
I understand that Andy but what I meant was would it be an out right fail or are you given the opportunity to rectify with a revisit? Or possibly just photographic proof that the remedials have been done without a revisit? Thanks
That would be down to the assessor. I would reckon you would be questioned about any serious non conformity related to your work. I also reckon you would have had to have demonstrated high levels of negligence and incompetence to actually fail though.
The way the NICEIC is run these days I would reckon it would be a chargeable re visit for non conformity, it certainly would be for a "fail"
Knowing the NICEIC if its them, then worse case scenario unless the install is really really bad is they will arrange another assessment visit in due course once any issues have been rectified - for another fee of course.
They do like to get you to do your RFC tests though and you could risk it but if they ask you to test that circuit you are up the creek without a paddle. dont try and blag it, you have time before Saturday to sort this but need to get working and to be able to explain to the assessor what you have done and the reasons why. let us all know the outcome.
Cheers Gavin. I don’t get precious about constructive criticism. I kind of expected what the response to the post would be.
Hi Murdoch 100Amp BS7671. Was 25mm already to meter from fuse. I upgraded to 25mm from 16mm load side of meter. Main Earth already 16mm, bonding to gas and water already 10mm.
Reply to No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
Promised a photo…. Remember, this was working…. And they managed to move in without hitting it…
