no earth terminal. what would you do? | Page 6 | on ElectriciansForums
Discuss no earth terminal. what would you do? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
as title. using existing back boxes ( lighting) as original VIR cable in capping and managed to re-use route to save chasing. boxes are tight and nailed in. removal would cause a lot of damage to decor. no earth terminal in box, so my solution was to drill the side of the box and fit screw. obviously a 2mm HSS bit is no good to drill into the brick, that's why it's in the side. would have been neater if I'd gotmy box of ring crimps on site, but hey ho. at least the box is earthed.
[ElectriciansForums.net] no earth terminal. what would you do?
As number one grammar and spelling pedant, I do cringe sometimes...I mean, criticism is MY job, ok?
Anyway, I am off to sail the Spanish Main tomorrow morning, so I'll catch you lot on Monday as my ship has no internet access.
I need a break from the Shed. "Pirate, we need to fit these cupboards and that thick green and yellow wire from the fusebox to the water pipe is in the way. Could you disconnect that for now, and redo it when you get back on Monday?"
"Are you switchng off the electricty, then?"
"No, but we'll only be using some drills and stuff, and the cooker."
Night night, me hearties!
customer don't like either he prefers painted plaster. even so, he's got a good base for it, no bloody great holes or chases down the walls, less mess, less cost, everyone's a winner.
Reply to no earth terminal. what would you do? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
