no earth terminal. what would you do? | Page 4 | on ElectriciansForums
Discuss no earth terminal. what would you do? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
as title. using existing back boxes ( lighting) as original VIR cable in capping and managed to re-use route to save chasing. boxes are tight and nailed in. removal would cause a lot of damage to decor. no earth terminal in box, so my solution was to drill the side of the box and fit screw. obviously a 2mm HSS bit is no good to drill into the brick, that's why it's in the side. would have been neater if I'd gotmy box of ring crimps on site, but hey ho. at least the box is earthed.
[ElectriciansForums.net] no earth terminal. what would you do?
Should have put a metal switch plate in.
Then you could have taken the CPCs to the switch plate and the back box would be earthed through the screws.
thatwould be a solution but customer wants plastic. metal/chrome accessories would add a couple of hundred on the job.
well, i'm not going to give you dililah, even if it is the best cover alex harvey did and SCFC anthem, so how about coming upwith a song with Olga or Grazynya in the title???? hmmmm. :D:D:D.
Gotta disagree Tel .... this is the best cover that SAHB recorded ....
Lucien's tip is one of my go-to methods,together with a couple of other,tidy remedial additions...but Tel did what he did,with what was handy,and then had the sand to tell us and post the pics :cool:
He could have stud welded a SS terminal block...he could have not bothered doing anything...somewhere in the middle,is where most of us are :)
would be nice to do that, but box nailed in, 1950's plaster tight round box. getting box out would lead to the room needing redecorating. sometimes you need to balance the costs. already re-used the original capped channels to save chasing.
So let them redecorate.
Do you really think it is better to place a persons life at risk than leave them facing the cost of re-decorating?
"anyone who claims to know everything is a liar and a heathen"
True, but in my retirement I have learnt so many songs that I can now confidently say that if you give me a name, boy or girl, I can find a song with that name in it...and because I am an old git, I know I have done this before!
Anyway, leave a safe job...Tel, you did.
Happy birthday to......
that fix i did is a good an earth as any factory fitted brass terminal with a titchy 2mm screw in it.
Reply to no earth terminal. what would you do? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
