No electric in my garage | Page 3 | on ElectriciansForums
Discuss No electric in my garage in the UK Electrical Forum area at ElectriciansForums.net
G
gimpchop
Hi i had my garage converted in to a office about 5 years ago. Today i went out to my garage and there is no electric. I have checked the mcbs in the garage and they are all in the correc possitions and allso the main mcbs in the house and all are in the correct positions can any one point me in the right direction in to trouble shooting it pls.
Thanks maybe I explained it wrong there is mcbs for sockets lights ect but nothing tripped.
The spa came with a 240v plug and is ment for household use. The spa allso has a circuit in line that didnt trip.
Thanks yes the damage is to the rcd. The join is where the cable comes out of the house and is joined to armored cable that goes underground to the garage its inside a waterproof box and there is no damage to it heat or age related but it is conected with a standard conetion block. Not sure if it the right one for the job.
This is a pic of the join.
[ElectriciansForums.net] No electric in my garage
replace that connection block with wagos.then look at the RCD thast's damaged. it will have a mA rating (trip current) and a A rating (max. current load) let us know these 2 values.
also, i can't see that the armour of the SWA ia earthed. that is bad.
Reply to No electric in my garage in the UK Electrical Forum area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
