No electric in my garage | Page 5 | on ElectriciansForums
Discuss No electric in my garage in the UK Electrical Forum area at ElectriciansForums.net
G
gimpchop
Hi i had my garage converted in to a office about 5 years ago. Today i went out to my garage and there is no electric. I have checked the mcbs in the garage and they are all in the correc possitions and allso the main mcbs in the house and all are in the correct positions can any one point me in the right direction in to trouble shooting it pls.
Hi im telling you as much as i know all the work so far was carried out the electrician that was hired by the builder that converted the garage or when the house was built.
I think the fact you keep fishing for information after being told you need an electrician in to sort out the problems and test the arrangements as safe to use is making people suspicious. They may be suspicious that you intend to fix the problem yourself, and possibly installed the circuit, complete with faults, yourself.
You can allay these suspicions by calling out an electrician to sort this for you.
Ok thanks to all for the info. I havnt installed anything myself. I admitedly thaught if its a case of replacing the switch i feel confident to do that myself but with the other thing hilighted i will ring someone thanks again.
This is the wise choice. It is not just a case of swapping components. There are issues to be addressed with the methods of installation and circuits will need testing with the proper equipment and knowledge of testing procedure.
Reply to No electric in my garage in the UK Electrical Forum area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
