dlt27
- Joined
- Jul 4, 2011
- Messages
- 196
- Reaction score
- 30
Hi all, I have just read a report by BRE on the effects on cable supports caused from fire. It stated the obvious about the plastic clips, plastic conduit etc failing. However what I found interesting was that the metal supports failed due to the plastic rawl plugs failing. So I just wondered what is the point of using non combustible supports if the rawl plugs fail. ( in concrete that is). Does this mean we should be fixing saddles up with those concrete screws rather than plastic rawl plugs!
