View the thread, titled "Notifiable works." which is posted in UK Electrical Forum on Electricians Forums.
J
jones68
I am building a small timber frame extension for a client and am planning to wire it myself , I have a part P domestic installers qualification with the 17th C&G. I want to check whether this is notifiable work. As the plan is to extend the existing ring final circuit and lighting circuit only and not add a new circuit my understanding is that it`s not notifiable and can be covered by a minor works certificate ? Any advice much appreciated.
I had a lets say discussion with the NI at elex,and brought up part P and how it came to be,now when I first heard the story of how an MP's daughter had been electrocuted by dodgy electrics I was a tad annoyed to say the least,the impression I got was a small child killed by some dodgy wiring.Then I got the full story,which I hasten to add was lets say blurred to sell a good story.The daughter in question was 30 odd years old,she got killed when her leg touched a dishwasher and her hand touched a metal rack,which had been fitted by her husband,on a wall in between 2 sockets and which people had complained of getting slight shocks off for ages.Now I know we don't like DIY books BUT read any book and it always tells you to avoid drilling into walls in a line horizontally between sockets or vertically above or below sockets or switches.Thats basic common sense,without getting involved with cable detectors or anything else,now lets be honest,regardless of whatever the electrician did that was wrong,ultimately it was the fault of the person who fitted the rack to the wall,her husband.Was he criticised in court? NO! Why because they wanted to blame someone else,and on the back of this to fleece electricians.
I often wonder how many other similar cases there have been in the last 10 - 15 years where the person involved was not related to an MP so those incidents didn't get the same publicity.
The effectiveness of Part P is difficult to measure as the introduction of BS7671:2008 with the RCD everything line must distort any data collected as there is no reporting of how many times RCD's are tripped and what the circumstances were when it tripped and whether there was a danger to life
It also sounds your against any regulation does this include any form of licensing of electricians as this is something that could rear it's "ugly head" as an alternative
Nothing ugly at all about the licensing of all electricians, in fact it could well be the saviour of UK electricians.
One things for sure it'll remove any need for scam providers and their bloody joke of a competent assessment, that frankly the dimmest school leaver can pass, a couple of weeks or so after leaving school....
what never came to light with this case is whether the cable in question was correctly routed in a safe zone, whether it was RCD protected or not, dependent on the reg. in force at the time of installation, if the cable was install in accordance with thew current version of BS7671, then the blame rests solely on whoever drilled into it, and the customer for not acting on the fact that repeated small shocks had been received. but, then again, an MP was in the equation, so blame culture comes in. it's got to be someone's fault, not ours, blame the spark.
I agree with the comments you have made and they are along the lines I was thinking the ugly term was used in response to Glennspark's comment about abolishing Part P with no replacement rearing it's ugly head so it's a bit out of context now
The industry needs cleaning up and the term qualified needs reinstating as opposed to the competent term that has taken over in recent years and then it needs to be enforced
It always amazes me that these industry bodies never defend the industry in these cases where it is found that the problem is not wholly attributable to the spark that did the installation all they do is look for another way to take money off the mugs who will sign up to their scam
Well thank you all for the incredibly helpful posts, all based on sweeping bigoted ideas about who I am and my skill level and ability in the electrical field. No doubt you all went to oxford before deciding to be sparks or maybe , possibly you all failed horribly in school and had to spend 5 years in tech college learning ohm`s law! Sorry to imply any stereotype.
I have been in the building trade for 20 years, high end guild of craftsmen quality in all fields and have recently started to add electrical qualifications to my skill base so that I don`t always have to wait on sparks to turn up and trash the build before I can get on!
I asked a very simple question regarding interpretation of building regs, my work has passed inspection by building control, I have also been lucky enough to gain experience with an excellent electrician , I will ask him this question when he gets back from his holiday or just ask my equally helpful building control officer.
You`re mostly a very very sad bunch who clearly need to get a life!
----er
In bold - then why the question?
Very short sighted comment IMO Part P is only a section in the building regs that could be rewritten and/or revised to rid it of the problems it currently causes and the scams and trainers that exacerbate everything that Part P was supposed to solve
i wern`t on about a proper, recognised licence
i were on about some other crap in the mould of partP...
just a peter & paul excersize...
Pot and kettle!!
Well thank you for your bigoted opinion you obviously have very very little knowledge of the electrical industry if you believe the PROPERLY qualified sparks on here spent 5 years just learning Ohm's law. If that is all you managed to learn in your 5 weeks then you certainly have plenty more learning to do because you have been brain washed by whoever told you that ohm's law is all you need to learn
You sound like the typical ignorant jobbing builder who is a master cock up merchant that blames other trades for your short comings. Apologies for the stereotype
Did you not think to ask your "high end guild of craftsmen quality in all fields" or do they not cover electrical yet because you are still in training and you are it's only member. Dare I ask how your "excellent electrician" learnt his trade as you don't appear to be getting much benefit from his experience and we won't go into why your building control officer is so helpful and it's not clear what aspect of your work has passed building control inspection
I think you need to get your head out of your rectum. The public needs protecting from people like you that think they a a master of everything they touch
Thank you for your posts it's been a pleasure discussing them
Hmm
yet another multi trade superstar coming on here wanting hugs n kisses from qualified electricians
after cutting out the part that the electrician does.
This carry on needs to be stopped in its tracks.
its only some wires after all eh?
UNG....
you cant educate pork mate...
Reply to the thread, titled "Notifiable works." which is posted in UK Electrical Forum on Electricians Forums.
