devlin maguire
is a double socket one or two points
Discuss number of points served in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
omg did this thread cause a discussion at work today.
one has been saying a d/skt is 1 point
and other lad has been saying a d/skt is 2 points
both submitting said details on test sheets
so...
how many points would you count
a 2g switch as
3 lamp holder chandelier
s/f/s + s/skt fed off it
I would count a 2g switch as 1 point. The wires are taken to one point in the building, there is one point to open for testing and there is one electrical accessory there (the switch). If the light switch includes two circuits, eg hall & landing lights, then I would count it as a point on each circuit.how many points would you count
a 2g switch as
The important bit is 'connection of current using equipment'.
surely then there are two points at a double socket?
Reply to number of points served in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
