Old DNO supply | Page 2 | on ElectriciansForums
Discuss Old DNO supply in the UK Electrical Forum area at ElectriciansForums.net
Norwich
Hey guy's,
Anyone ever been asked to price up a new db and found this as a main earth?
[ElectriciansForums.net] Old DNO supply
You might find a shop up there. Earthing systems very often TN-S. If connection to conduit is sound then normally okay. If you say yours may of been overhead then the earth to the conduit may well just be earthing the conduit.
Are you a competent bat person? If not you you have to notify the LA prior to disturbing any bats in the loft. It will cost you £500.00 to cover the cost of the post inspection bat interviews.
looks like that earth cable is just earthing the pipe.those v.i.r. cables dont like being moved after 60 years
Hey,
The home owner is away at the moment so I haven't been able to get back in there yet to investigate (unless they have got another quote?)
Your right about them VIR's though, horrible stuff, I used to do a lot of live jointing on the DNO side and used to come across it feeding street light's.
Reply to Old DNO supply in the UK Electrical Forum area at ElectriciansForums.net
I should have an update on all of this come the weekend... And it may prove interesting.
Good thinking - the other side of that is my garage and also where the gas comes in so probably quite a tidy solution if it comes to it!
