One ring main covering a brand new 3 bed house | Page 2 | on ElectriciansForums
Discuss One ring main covering a brand new 3 bed house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for everyone's replys. It's a split board, one RCD covering 4 mcb's which are lights up, lights down, heating and cooker. Other RCD for the one mcb protected ring main. I'll advise her to talk to the builders about it but is it too late?
^^^^^^ can someone post up the reg numbers about this statement, just so wrong. I would do it myself but I no longer have the patience
I'd say definitley too late...he'll be back in eastern europe somewhere by now :38:
A ring circuit is allowed to cover an area not exceeding 100m square.
What's your floor area where this circuit covers?
That's not strictly true any more, it's a historic guideline. Still a guideline today, though. I'd say the biggest issues are potential overloading of the ring circuit, lack of circuit segregation and possibly circuit length.
Plus nuisance tripping by accumulative build up of earth leakage
I think what your all missing here, is that if this new build is part of a development companies estate, then the electrician(s) would be following an approved drawing and specification drawn up by either the development companies electrical Engineer, or the companies Architect!!
This all smells to me, like a cost cutting exercise by the actual developer using the Reg's to it's minimum requirements, rather than it being down to the electrician that installed the installation!!
Yes it's a new estate built by David Wilson Homes. I can't imagine a buildings inspector would accept work like this if it was was carried out on a rewire. Or maybe he would?
So what would you expect a Building Inspector to know about electrical installations?? These housing development sites are almost totally controlled by the developer themselves, and as i said, they will be working to ''approved working drawings'' and to a ''specification'' which were probably accepted by the local council LABC/Planning dept, prior to anything being built!!
majority probably 99% new builds you get a plan of the building,showing electrical services, you count it off and design yourself. The 10yr man inspects might snag for more clips, but he does not go the CU and count circuits. Then once signed off all he asks for is a copy of the cert, and demo of smokes etc and then hes happy. They never dabble to deep into the electrical side.
Ps the last inspector pulled me for not writing spare on the spares,and the lad doing the next house didnt put a label on the cu stateing next test date (as it read on snag sheet-no red label- being the niceic printed ones he was referring to lmao)
I'm interested in peoples fascination with ring final circuits? I haven't wired a ring for years! Radials every time for me :)
Noooo! Don't start that debate again......mind you I can't resist. :)
I think rings and radials both have their place but I install more and more radials these days. Some sparks I think still automatically think sockets = ring. I still install a ring for kitchens, but often radials for living room, bedrooms etc. Problem is, in my view there is no decent alternative to a 32 amp ring. A 32 amp radial wired in 4mm is limited in terms of installation method. You're pretty much limited to ref method C cos the CCC of 4mm drops below 32 amps pretty quickly! Not to mention the 1.5mm CPC limits circuit length.
If you exclude kitchen/utility areas what realistically do you expect the "load" to be in the average house for a ring/radial - not much.
Reply to One ring main covering a brand new 3 bed house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Oh, and she wanted an electric shower over the bath...but that is another story!
