Outbuilding on non RCD side of C/U? | Page 2 | on ElectriciansForums
Discuss Outbuilding on non RCD side of C/U? in the UK Electrical Forum area at ElectriciansForums.net
N
Nicebloke
If running power to an outbuilding (usually a garage at the bottom of someones garden), I normally run it from the non RCD side of the C/U in the house and then put a 2 way RCD protected C/U in the garage. I was however, told that I can no longer do this as it must be connected to an RCD in the house C/U. I was also told that any outbuilding more than 20 metres away from a house must have it's own TT system?
This is where it all goes wrong when you have different bodies giving different opinions, and within those bodies you have people who seem to have their own misguided opinions. One body, one set of rules is what it should have been.
Its all down to economics
A ridiculous attempt at regulating domestic electrics in a market driven arena has resulted in Tom Dick and especially Harry becoming overnight pretend electricians signing up to the least costly player
The least costly player has no historic base or experience of the industry,it has had to recruit its team to meet the lowest cost demand
That team will also include inexperienced assessors gleamed from a pool of sparks where the skill level has been decimated since the introduction of that hatchet of the trade of electrician,Part P of the building regs
As a contrary opinion to that I can say that my stroma assessor was a time served electrician with many years experience and seemed to be a very knowledgeable fella.
Andy,I don't doubt for a moment that they have assessors who are at the top of their game
quote
OP, I would consider emailing your scheme's technical support, and seek clarification on this matter. I find emailing gets a more defined and considered response, than by speaking to an individual.
I'm with Elecsa, and quite often I've read & heard conflicting guidance on issues (nothing as profound as this mind), when watching their web broadcasts, and what is written in their 'Connections' publications. The last one was about upgrading bonding, it used to be it was okay to leave as is, if there was no sign of thermal damage. Then the mag' said, no it must be upgraded, then the dynamic duo said, it was ok to leave etc. :rolleyes:
Reply to Outbuilding on non RCD side of C/U? in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
