Outbuilding on non RCD side of C/U? | Page 3 | on ElectriciansForums
Discuss Outbuilding on non RCD side of C/U? in the UK Electrical Forum area at ElectriciansForums.net
N
Nicebloke
If running power to an outbuilding (usually a garage at the bottom of someones garden), I normally run it from the non RCD side of the C/U in the house and then put a 2 way RCD protected C/U in the garage. I was however, told that I can no longer do this as it must be connected to an RCD in the house C/U. I was also told that any outbuilding more than 20 metres away from a house must have it's own TT system?
OP, I would consider emailing your scheme's technical support, and seek clarification on this matter. I find emailing gets a more defined and considered response, than by speaking to an individual.
I'm with Elecsa, and quite often I've read & heard conflicting guidance on issues (nothing as profound as this mind), when watching their web broadcasts, and what is written in their 'Connections' publications. The last one was about upgrading bonding, it used to be it was okay to leave as is, if there was no sign of thermal damage. Then the mag' said, no it must be upgraded, then the dynamic duo said, it was ok to leave etc. :rolleyes:
Dynamic Duo One has to be TC who is the other?
^^ so what did you say when he made his "claim"?
I explained why I did it the way I do, and he said it still had to be on an RCD in the house C/U. With regards a TT system being required if an outbuilding was more than 20 metres away from the house, I just said that I honestly wasn't aware of that.
I could have asked him to show both the above in the regs, but I just wanted to pass the assessment (which I did), and I admit that I did slightly doubt myself that he must be right as he seemed so confident.
I have had assessors before from another body who knew their stuff, so as already suggested some are clearly better than others and it's the luck of the draw.
As suggested, email and get clarification.
Darren Staniforth. The pair of them, quite often seen travelling the length & breadth of this country, spending my money on expensive hotels, cordon bleu meals and fine wines :mad:
Yeah they are advertising ATM for some one to replace Tony cable as he's retiring...To work along side doppy Darren :eek:
Because some single pole rcbo's will only disconnect the L leaving the N connected in a fault, so if you had a N - E fault the rcbo would trip, but the N - E fault would still be present and current will be flowing. the upfront s type would detect this and trip. Kind of like a backup really if that makes sense.
Reply to Outbuilding on non RCD side of C/U? in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
