Outside light & rcd | on ElectriciansForums
Discuss Outside light & rcd in the Australia area at ElectriciansForums.net
J
Jimmyb
Do outside light require rcd protection ?
All cables are surface monuted in conduit in store room and then though the wall to outside and upto light.
The rationale here is that as it's attached (and not buried) then no idiot should put a drill through it (unless it's a kitchen fitter with a long drill bit from the other side of the wall ;) ).
The conduit (mech protection) eliminates the need for the RCD, assuming that the circuit is designated for this outside light and not tapped off the existing lighting circuit/FCU from ring, then you would need to upgrade that circuit so as it was covered by a RCD, again on the likely presumption that there would be cables buried in the wall for ring main/lighting circuit
The only lights as far as I can see that Require additional protection by the use of an RCD is covered in regulation 559.10.3.2 and are recommended for telephone kiosks bus shelters and those town plan cubicles.
So regardless in a domestic situation of whether to light is attached or not attached to an outside wall, unless you need the additional protection for the cable or for a special location then no the light does not need RCD protection.
Where mate?...as far as I am aware fixed equipment outdoors and not covered by section 7 does not require RCD protection....end of.
411.3.3 (ii)
Crikey. I seem to have got mixed in my regs. Apologies OP for my blunt cobblers. I have learnt something.
I've always believed outside (fixed) equipment required 30mA RCD proctection but maybe it doesn't need it as a rule. I'm just used to it always being there anyway (a new install everything, bar perhaps a surface mounted light in the cupboard where the DB is) will be RCD''d in a house ..... And there's usually a chance the light outside will be fed from a switch with cable hidden in the wall etc etc but I take the point (and found the bit about kiosks, ! :crazy: ) Still a bit dazed at that, still its a big book that red (sorry green) book
Reply to Outside light & rcd in the Australia area at ElectriciansForums.net
Usually if there are only C3 observations it would usually be deemed satisfactory but could be found to be unsatisfactory in unusual...
davesparks
As long as the existing wiring is approved for outdoor use and everything is working as planned then there is no need to replace the wiring.
