View the thread, titled "Part P" which is posted in Australia on Electricians Forums.
DurhamSparky
Just to sum it up
Part P is a building Regulation that is statutory and which must be followed when carrying out electrical work in domestic property.
Part P is NOT a qualification and any body going around saying they are Part P qualified and have a certificate are talking Bull....!! You DO NOT need to do a 2 week VRQ course
Electrical Course | Part P Electricial Course like this one with a training scheme to register as a Competent Person.
YOU NEED TO BE COMPETENT....!! this can be achieved by undertaking formal Electrical Quals at a college or by a training provider...!!
You do however need to know about the building Regs and Part P....!! you can download Approved Document P from the planning portal website.
The following schemes are the most popular with domestic sparks. Elecsa, Niceic and Napit. Upon registration with them you will be required to conduct a formal technical site assessment that will involve you changing or modifying the electrical set up drastically (Rewire/ Cu Change)
If you pass the assessment you are then freely allowed to carry out work in areas designated by building control that fall under the Part P umbrella http://www.partp.co.uk/downloads/public/CLGbuildingworkleaflet.pdf and any work that you carry out can be notified and signed off through them (the schemes) at a small cost (£2-4) and they will inform LABC for you.
If you decide not to register with a Part P scheme. be preared that notification of work to LABC can cost hundreds of pounds and drastically increase your price. They will also expect you to still carry out the tests and paperwork before they arrive to SIGN IT OFF
Recommended courses to do are:
A formal Technical Certificate that is achieved at Level 3 on the NQF (National Qualification Framework) i.e
C&G 2330 or BTEC Advanced/National Diploma.... This gives you the Underpinning Knowledge to build on. (achieved via college or distance learning 18months - 24months is time scale)
You will also Need 17th Edition Wiring Regulations C&G 2382 (if you dont have this you wont get any where in the trade.)
NVQ 3 2356 (its a Craft Certificate that although not needed is very desirable and normally achieved when doing an Apprenticeship but now freely available to "Bolt on" to your current Qualifications via distant learning.
C&G 2391 the ultimate qualification in the electrical world..! Inspection and Testing only to be achieved with considerable site and technical knowledge, closed book exam with a 30-40% pass rate.
C&G 2392 (lesser qualification of the 2391 and aimed at new sparks with little knowledge of inspection and testing, normally used as a starter course to grasp the fundamentals of what's required)
Signing off your work..!!!
you DO NOT need 2391 to sign of your work but you will be expected to have knowledge of inspection and testing to an achievable standard required to carry out and fill in the test results.
You also do not Need 2391 to carry out PIR's but should any thing happen and you go to court the 2391 certificate is your lifeline to prove competence in the field.
hope this helps...
comments and alterations welcome
Hi everybody
I was hoping to get some answers because i'll be honest some of the qualifications are confusing me. I am looking to retrain as I have a degree in computing and absolutely hate everything about it.
I understand that the first qualification i would need would be the Certificate in Electro Technical Technology level 2 and then level 3. Am I right in assuming that I need to be working in the field to be able to do level 3? What time scales does it take to gain these? I read earlier in the thread about 18months to 24 but does that one level or both? A college close to me does level 2 over 34 weeks, 1 day a week.
After that I believe i would need to look at getting 17th edition.
Am i right here or am I talking complete nonsense.
any order you want!!! i suggest doing 17th as early as possible as its a good course for referencing your Level 2/3 work against as you will be using it every day!! if you learn the book the therory will follow!! then you put all that in to practice during level 3 (if you can) or when you finish level 3 and do the NVQ!
I've found the route as clear as mud - and I suspect the colleges and 'oversight' bodies like to keep it that way!
I did 2330 L2/L3 in at evening classes over two years - it just seemed like five ... Then I crammed in 2382 via on-line learning packages, and found a college that would allow me just to sit the (PC-based) exam for about £60.
I then did 2391 in a 4-day course and found that more useful than 2330 and 2382 combined. Did the 2382 and 2391 in space of about 2 months after finishing 2330 L3 - having it all fresh in my mind helped, but the best way would be take you time and get lots of practical experience first.
Now the real learning begins ... :)
With your computer background you may find some of the college course way too long - but if they can make a course last two years instead of just one that's more dosh to the colleges...
mmhm the college I am looking at would allow me to do both so guessing that will be the best option. To get the level 3 qualification do I need to be working with electrics or can still do that along side my current job?
Do you know also whether the college route or one of these intense courses are better?
Sorry for all the newbie questions
Ian
Wish I could help you on that question - when we started our 2330 L3 there was a rumour going around that the college shouldn't have allowed everyone on it, as a number of us weren't working in trade - including me.
I never found anything in balck and white on that - which is how it should be. The system should allow us a number of different ways in.
I'd recommend you do the L3 and start picking up as much experience as possible as you do it - offer your time to mates for free - there'll be guys on the course working in trade that may be able to get you in as labourer at weekend, etc.
I've been at it 3 years in September - doing the courses. Still doing the 'day job, but starting to pick up more and more part time paid work now I'm 'qualified', and aim to get NICEIC soon. From there, depends on how the work comes in ... :rolleyes:
I am an approved JIB electrician and have an NVQ level 3, the 2391 and my 17th edition.
Do i need to do a part P course or just be registered and have insurance to be able to do domestic work?
Nobody 'has' to any courses it's all about your knowledge and experience of applying 7671 and the paperwork that goes with it, if you have 2391 and are useing it on a frequent basis your assessments will be a breeze, pick a body and do the two assessments stil gonna cost you a few quid tho !
could someone please help, I took the part p on-line exam a week ago (failed had questions about roofing and bricklaying) I have downloaded the approved documents I just wondered if the "electricians guide to the building regs" was worth buying. Did it help U pass the exam?
Reply to the thread, titled "Part P" which is posted in Australia on Electricians Forums.
