Part P | Page 4 | on ElectriciansForums
Discuss Part P in the UK Electrical Forum area at ElectriciansForums.net
G
Guest77
It is a Building regulation, thats right a Building regulation, not a Electrical qualification. If you read it (you can download it on-line) then you will see that some works, and only some as it is getting less now needs to be notified to the local building control. Now there is nothing to suggest an Electrician need notify the local building control authority, nothing at all anywhere, this is a myth, and a myth we are all getting fed up with. The customer is duty bound to do this just like if they decided to have a loft conversion or indeed a extension on their home. To be competitive some electricians join a scheme so they can notify for the customer on their behalf and the fees are usually a couple of quid instead of the 2-300 the local authority would charge the customer if an Electrician didn't do it for them, this way the customer gets to save some money and the Electrician wins work. The schemes have a policy which they suggest if they get people to join them they will guarentee to the local authority the people they approve are competant, for this privilage they take 400-500 off these people, usually Electricians, but some Plumbers and Kitchen Fitters join as well, The local authority building control then accepts the fact the people on these schemes are competant and do not go out to site to inspect the works, this is why the cost is just an administrative one at a few quid and not hundreds. If you are a competant Electrician for example with a Gold card and plenty of experience why do you need to pay a scheme hundreds of pounds a year to have them tell the Local authority you are competant? If you are Competant then get stuck in and start work. If the work you do does need to be notified then you can ask the customer to do it or include an extra couple of hundred on top of your quote for you to do it. There is no judge in the whole of the UK who will find you guilty of anything wrong doing if you carry out work to BS7671 correctly without being a member of a scheme, we don't need them do we? so why are we paying them 500 a year? I can confirm I no longer pay them, I have left the NICEIC, I am competant, I have over 30 years experience, I will not give them 500 quid to tell someone else I am competant.
Please do not keep going on about being part p qualified, it is all Rollocks, rant over.
The responsibility for all Building regs notifications is with the Home owner.
Enforcement action is taken against the home (building) owner.
From the Planning Portal;
if you are the
person (e.g. designer, builder, installer) carrying
out building work to which any requirement
of Building Regulations applies you have a
responsibility to ensure that the work complies
with any such requirement.
have you even read that quote, it clearly says that the person carrying out the work is responsible in the first sentence.
Paragraphs are a bloody brilliant invention, you should give them a try.
Directly lifted from Approved Document P
"Most building works and material changes of use must be notified to a building control body unless one of the following applies-
A ) It is work that will be self certified by a registered competent person or certified by a registered third party"
I've just read through the rest of it and there is nothing in there that suggests to me that the installer has any other obligation than to test and certify the installation and to hand copies of that paperwork to anyone other than the person who ordered the work to be carried out
some seem to cling to part P like its a grail or something....
if you want to launch a campaign of civil disobedience against something you disagree with, then go right ahead.
Just don't do it by tricking people into joining that civil disobedience campaign by telling them that what you want them to do isn't illegal when it clearly is - that would be a ****s trick, and I'd hoped that you were all better than that.
ps speaking as someone who ran police liason for dozens of raves, and proper direct action protests including one that the state put 12,000 coppers up against (including several long term undercovers), I've no objection to actually taking direct action against a law that's wrong, just against tricking people into doing something that has the potential to see them end up prosecuted if the establishment decided to crack down on those who were causing them grief (which is usually what happens eventually IME).
I linked to the part in the actual building regulations legislation earlier, as well as quoting it directly.
It states, Has a Responsibility to comply, doesn't state has a liability or obligation to notify
the notification is a requirement of the building regulations that it's stating that the person carrying out the work has a responsibility to comply with.
And what do you think that the phrase 'responsibility to comply' means in terms of a web page offering advice on interpreting legislation?
it means that you're legally responsible for ensuring that all applicable building regulations are complied with, and as with most laws, if you fail to comply then you can face prosecution for that failure.
This is getting a bit tedious now. No matter how this point is argued, the facts wont change, you as the tradesperson are responsible for the notification of building control, as clearly stated in the act, and confirmed by the case law I've already given where people who weren't the building owner have been prosecuted for this.
Lots of uses of the words "You should" and "Your home" etc. Seems pretty clear cut to me, I'd suggest the case notes presented above were more relevant to the installer falsely claiming to be a CPS member and not fulfilling the duties that would be reasonably expected of one.
Does this help?
Read the first bit and then scroll down a little way to Local Authority Building Control/
Planning Portal - Electrics
If you are carrying out electrical work in your home or garden in England and Wales, you will have to follow new rules in the Building Regulations.
[h=2]Disclaimer[/h]This is an introductory guide and is not a definitive source of legal information.
Not really, it's an introductory guide aimed at the home owner, not at the tradesman involved, therefore it's focussed on the home owner's responsibilities.
eh?....
hark at this one....lol....lol..
he chunters on about "civil disobedience".....lol...heard it all now....lol.....
Reply to Part P in the UK Electrical Forum area at ElectriciansForums.net
That's a glass half full thought 🤔
2 3
Persons who are not registered with a self-certification scheme - including DIYers - will need to notify or submit plans to a Building Control...
