K
Krabby Patty!
Have you got a copy of this book?
Yes....
trying to get my head around this ‘Testing Fixed Appliances’ but reading the previous posts I am still at a loss?
Krabby……
Thanks for helping, Im on page 72 and i still am not quite getting it....(must be thick) sorry.Take a look at page 72![]()
That’s really good information and help.
Nail on head!
Yes I was worried that I needed to be a qualified electrician to remove the spurs to test etc and didn’t want to take them off for some ‘raincoat’ to tell me that I shouldn’t be doing it that and needed to be a qualified electrician.
I’m happy isolating them and completing the actual testing job in hand and fully appreciate your advice regarding the extra time needed to complete the testing.
Kind regards to all.
Krabby !
If you are thinking you would need to be a qualified electrician to take apart a FCU, and then to refit it, then think again. There is no such thing as a qualified electrician. However, when working on an electrical installation, you do need to be competent to undertake the work involved. But then there is no specific definition of what a competent person is. So I would ask myself this question - "Am I competent to safely isolate the accessory, to confirm that isolation, to then remove the wires from it for testing, and then to reconnect those wires correctly and re-energise the accessory?" If the answer is a confident "Yes" then there will be no problem. It would help if you had any sort of formal training in wiring electrical accessories, but is not entirely necessary.
The next questions to address are a) do you have appropriate test equipment/adaptors for this work? and b) have you priced the job accordingly (this operation will take far longer than with equipment connected with a normal plugtop)?
To muddy already murky waters, the learning lounge- part two PAT testing; items to be tested, informs us that built in equipment is not expected to be tested during a PA test but to be tested during a periodic inspection and test.
Sends shivers down my back as I got overdosed on Dave during 2382 and 2391.
nub of the question is why is fixed appliances being ignored because guys who are PAT testers only and not electricians cannot test them
