Peak output | on ElectriciansForums
Discuss Peak output in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
W
wstevew
One of those days today where the clouds go and you see a peak, But highest I have seen on mine 3.840kWp east/west system SB4000TL
[ElectriciansForums.net] Peak output
From a production point of view it always has, just luck it stayed on the roof until they refitted :)
However all that power down an 2.5mm T&E and SMA say it should be 6mm
PS. Thanks for your advise about the refitting.
fwiw, I've just downloaded the data from a 4000Tl we installed last September, which we had bonded to the MET (skylights right next to it) and it has irregular 601 DC grid feed in notices mostly early morning and evening as well, so I really don't see that the bonding makes any difference to it.
No. the top technical man from the installation company is supposed to be making a visit this week to take a look at the system.
I did email SMA again last week and set out how the system is wired etc. Thats when they pointed out the 2.5mm is not enough.
1) They first suggested the event message could be fixed by a firmware update. I said its on the latest firmware already.
They said array bonding is a decision to be made by an installer as every installation is different. Some bond every installation and others do not. (this contradicts their first response a while back).
Their response about the 6mm wire was:-
If 2.5mm cable is used anywhere on the ac side of a SB4000TL the inverter could disconnect frequently when approaching full power. Our inverters constantly measure the resistance of the AC circuit, an if this goes above 1ohm they will stop feeding in. Resistance of a cable increases incrementally in line with the power going through it.
2.5mm cable is allowed by UK regulations on domestic circuits that can operate above 4kw but assumptions are made that this is not a constant load (i.e. appliances such as washing machines switch on and off during their cycles).
A 4kw PV system during a bright day can feed in constant 4kw for up to 6 hours which can put undue strain on a cable if it too small. Hence the 1 Ohm safety limit.
I couldn't see how it would fix it, but originally SMA said it would. then firmware, and now they say the cable may fix it and that intermittent faults are a process of trial and error. Clutching at straws comes to mind
My installers technical man asked to come and look at the system due to the 601 errors.
He checked the inverter was set up right. I had already said it was but he wanted to see for himself which is fair enough.
He is saying he sees no reason whatsoever why 2.5mm twin and earth would be a problem and changing it will just inconvenience me. He said he would do a bit more investigation.
This may be true but I showed him the email from SMA and said if you don't do what they say you wont get any further with their support if they are saying it could be the issue as it is not to their recommended standard.
I would be grateful as always for your feedback.
Reply to Peak output in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
Thank you so much for your input! I will speak to octopus and see what they say regarding a new tariff.
