periodic report ???????? | Page 3 | on ElectriciansForums
Discuss periodic report ???????? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A well known local firm to me consistently do PIR's on EIC's and provide them to the local authority.
code 1 are really for immediate danger and should be rectified before being used or isolated,most are code 2 as they need improved,how old is wiring, check on gumtree for electricians to do work as you will get a lot cheaper than that too, there is no legal requirement on who carries out work,The lighting circuits would recommend getting done and earth to all switches etc but you may have earth through mainframe system ie trunking, conduits etc, if im being honest i would probably recommend getting retested and if there is discrepancies in work to be done I would then contact him for money refunded and report him to governing body and trading standards
Reply to periodic report ???????? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
I think it is a good idea in general, it provides a form of proof that the landlord has provide access to the required documents. further to that...
