Pick the bones out of this baby. | on ElectriciansForums
Discuss Pick the bones out of this baby. in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
UK
[ElectriciansForums.net] Pick the bones out of this baby.
I’ve never seen so many Henleys, most of them just floating in mid air.
Found in cupboard in holiday cottage I’m at.
A lash up, to outdo all Lash up, or as our US cousins would say it's a Mother of all Lashups (MOAL) as opposed to the the big bomb the MOAB
Is the area a bit **** then? No good local pubs, restaurants, walks and so on?? Bet your Mrs is having a great time......
Ha....
Does a man that take pictures of “electrics” even have a missus?
Sadly first thing I looked at on arrival on Monday night, only just figured out how to post the pictures
not onlyis it an abortion, but wet-pants has struck again. soil pipe blocking switch fuse.
if you zoom in on the picture you can see the 'plumber' has put a nice sticker on with his phone number... could always give him a ring and tell him he is a plonker...
I also think you could turn the odd switch off and see what it does, if there are other properties fed from it you could always create a bit of work and a call out fee!
A bit of googling seems to show that the only disease carried that can affect humans is a rabies type virus and this has only been recorded on a species that doesn’t roost in houses. More likely to catch something from rodent or bird droppings :hamsterface::hamsterface::hamsterface::ant::cow::chicken:
I'm sure that will help here :)
Reply to Pick the bones out of this baby. in the UK Electrical Forum area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
