PIR and lights | on ElectriciansForums
Discuss PIR and lights in the UK Electrical Forum area at ElectriciansForums.net
Davem
Hi I am new to the forum I am currently rewiring my house and I have nearly completed (finally) but I am wishing to install two lights with pirs on the exterior of the house. I am having a normal switched outside light. But I also want two lights with PIRs to both come on when either is triggered. Can I have info on how to wire these and which cable I will need? I will also be feeding the lights from a SFCU and help would be greatly appreciated cheers
Hi Dave,
depends on the type of lights you have purchased, if there are 3 terminals (excluding earth), Live , Neutral and switched (maybe marked up as L1) then maybe, you would have to put a triple+e in between the fittings. IF not, u could get two seperate PIRs and two light fittings
As above switched supply goes to the other lamp and vice versa.
[ElectriciansForums.net] PIR and lights
I am believing that you clue have not and electrician qualified consult should. Further, I am thinking that DIY DAVE you are and that LABC consultationing should considered be in order to make sure safety is paramount. If doubt is in then an electrician of qualification should be consulting. Funerals less expensive than electricians are, also more traumatic. Please be telling me how testing you are?
Actually BIGHEADTREV I am a newly qualified electrician and I was asking for advice and information so take your 26years experience and leave this conversation I only want to speak with people that are willing to advise us new boys !!!
If you can't take a bit of micky taking boy then don't leave yourself open to it.
how i would do it is from FCU, T/E to a switch. then a 4 core flex to 1st PIR. ( L,N, SW). then a 4 core flex to 2nd PIR. then take a 3 core flex to each light from each PIR.
Reply to PIR and lights in the UK Electrical Forum area at ElectriciansForums.net
Some pir lights have a switched output so you can link them together, when any pir is activated then all lights will come on. if you don’t connect...
The existing wiring shows both brown wires into the same terminal. One should be in the terminal it is in now and the other in the terminal next...
