PIR and lights | Page 3 | on ElectriciansForums
Discuss PIR and lights in the UK Electrical Forum area at ElectriciansForums.net
Davem
Hi I am new to the forum I am currently rewiring my house and I have nearly completed (finally) but I am wishing to install two lights with pirs on the exterior of the house. I am having a normal switched outside light. But I also want two lights with PIRs to both come on when either is triggered. Can I have info on how to wire these and which cable I will need? I will also be feeding the lights from a SFCU and help would be greatly appreciated cheers
I do apologies but like I said I am new and looking for advise and info but because I may not understand what is being said I am being told I am Incompetent! Sorry for the rash comments !! Thanks for the advise we will leave it there for now until I have another issue hopefully not !!
so you bloody should be...
now go enjoy the forum
Are you still here TREVOR ????? WHY ? :/
Dave, look mate. sometimes I take the mick as everyone on here does. Sometimes it doesn't come across as intended, sometimes people get the wrong end of the stick because you cannot tell people's inflections from the written word but here's a little bit of advice for you....Wind your neck in son, everyone gets along a lot better when you do that.
does with me...sometimes...lol...
Underneath the surface this thread lays out the electricaltrade’s dilemma. Time served,
respected (by me),experts are unhappy giving out infowhich can be read and used by anyone.
Anyone over apprentice age who may have got thequalifications after career change etc.
can’t get a placementwith a firm/one man , and need to ask the everyday wiring set-ups.
Hi Dave,
depends on the type of lights you have purchased, if there are 3 terminals (excluding earth), Live , Neutral and switched (maybe marked up as L1) then maybe, you would have to put a triple+e in between the fittings. IF not, u could get two seperate PIRs and two light fittings
Probably not mate, you shouldn't be fitting t and e outside! Principle's right though.
I am believing that you clue have not and electrician qualified consult should. Further, I am thinking that DIY DAVE you are and that LABC consultationing should considered be in order to make sure safety is paramount. If doubt is in then an electrician of qualification should be consulting. Funerals less expensive than electricians are, also more traumatic. Please be telling me how testing you are?
Thats all gone out the window trev he can get it tested under the new changes of part p can't he lol
you don't need to be qualified to be a spark just competent will do lol
I do wonder why I'm paying every year though
but we see it all the time dont we...
Been doing Rising and lateral mains surveys for a London council, most of it's MICC with some SWA repairs which are OK barring the fact the Ryefields are mostly rotten as s**t...Nice continuity to the sheath methinks... but there are at least 7 16mm t&e's lashed in outside (old colours so not a recent stop gap), one's running across about 2 foot of dirt in a back yard half buried under smashed glass. :banghead:
Nice!
Nice!
i had one a while back....10mm twin feeding an outbuilding...not clipped/secured or owt...there it was just flailing about....
he had a length of 16mm 3 core armoured...so i just put that up for him...secured....
Reply to PIR and lights in the UK Electrical Forum area at ElectriciansForums.net
Some pir lights have a switched output so you can link them together, when any pir is activated then all lights will come on. if you don’t connect...
The existing wiring shows both brown wires into the same terminal. One should be in the terminal it is in now and the other in the terminal next...
