PIR codes | Page 2 | on ElectriciansForums
Discuss PIR codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thes codes are a complete waste of time they are open to imterpretation by who ever is testing, if you give a PIR to a client and tell them the codes indicate whats needed,how the hell can he tell whats important, the only people remotely interested is your yearly assesor. I mean, come on almost every installation will have a 4 you can apply that to any thing you like from a cracked face plate to a rewireable with a piece of coat hanger between the termnial screws and page 2 is often not big enough
A seperated printed report in plain english lets the customer know whats needed and at the end of the day thats what the ESC is all about
DM
Hi Devlin,
Yes I agree that plain english is the best and the codes used as you rightly say are always open to interpretation.
Personally I always carefully explain so the customer fully understands and has the option what to do next.
Best wishes,
Rex
The original list looks to me like a 16th edition list anyway.
But I would pick up on one
"CPC used as a live conductor (sometimes found in C/H systems and 2 way lighting)"
if the cpc is sleeved as live (ie brown sleve) and their is an alternative cpc or the equipment is class II then what is the problem. I am thinking particularly of boiler installations where two three core cables are used instead of a single 5 core, and a sleeved cpc is used as a switch live.
CPC in TW&E should never be used as a Live conductor as then there is NO CPC and if cut in the middle then there is no sleeving
If you mean on flex to things like PIRs and Boiler stats ect thats not as bad as cpc is insulated throughout but its still Shoddy work
I went to the IET presentation yesterday about the first amendment. Brace yourselves for the new 'Condition Report' to replace the PIR. It has its own Schedule of Inspections / Tests which look much more detailed, but they've ditched the Code 4 'does not comply but don't worry'. Google 'IET wiring regulations 2008 amendment' to have a look at the draft which includes other stuff like the new special location. Get ready with your sterilised meter probes!
Hi RexT
Code 2
19. Anyone circuit has an insulation resistance of less than 20 kilo ohms?
I take it this is a typo?
230/20,000 = 11.5mA
I think I'd call it a code 1 and disconnect it.
Or are we talking about Neutral to Earth?
I tend to agree with Devlin
Reply to PIR codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Commonly known as double knock, some pirs have a latch on time delay for a few seconds, giving time for the 2nd one to activate .
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
