A
andrew692003
Does anyone want to join? :)
As I've stated before I have never used these between floors or in any new builds so don't get out the sniper rifles straight away! ;)
The only time I have used clay pots has been in lofts where access isn't a problem and usually in older dwelling houses. Now, the last time I did this was a good couple of years ago not that that matters as I can't see a problem with it.
When fitting the pots I always make sure that the insulation is clear of the hole and all dust etc has been cleaned away then I fit the pot with the transformer outside lying on top of the insulation. I always push the insulation up against the pot which makes it very steady.
At the end of the day all you are trying to achieve is to stop debris falling on the lamp and letting the heat dissipitate to possibly stop causing fire so, does it matter whether you use a firehood, plasterboard box or a bloody clay plant pot?
Firehoods can be expensive and a PIA to fit, Plasterboard boxes take time to build and even the cheapest Firerated fittings can still up the cost considerabaly.
Cheers
Just for clarity
The Electrical Safety Councils stance is as follows
1. Clay pot as Fire hoods:
We have published a best practice guide (No. 5 Electrical installations and their impact on the fire performance of buildings: Part 1 ) that, in part, deals with the requirements for downlighters and fire hoods. The guide can be viewed at: http://www.esc.org.uk/pdfs/business-and-community/electrical-industry/BPG5_08.pdf
In the guide, we recommend that downlighters have integral fire protection. or are provided with some other ‘suitable’ form of fire protection. A suitable form of fire protection would be a purpose-made fire hood that has been designed for this use and that meets the fire performance requirements of BS 746: Part 21: 1987 and the construction/stability requirements given in Annex E of the guide.
A product (such as a clay flower pot) not designed for use as fire protection would not be recommended unless it can be ascertained that it could meet all the performance requirements mentioned above, which is very unlikely.
We hope you find this response useful.
Regards
2. Insulation separation with clay pots.
It may be, but unlikely in every case. Factors that would need to be considered include – adequate ventilation for the luminaire, thermal performance requirements specified by the manufacturer, weight on the ceiling, stability, etc.
Building regulations do not prohibit the leaving of a small area around downlighters free from thermal insulation where it is necessary to permit the dissipation of heat they generate.
Hope this helps
Clarity is always good.
for whoever might be reading:D
but it still unclear:
ESC said 'Maybe Ok to use pot but unlikely'.
No hard straight answer, it seems, because it has not been tested.
Difficult to argue against fire rated downlighters.! Although cost is ALWAYS an issue. Especialy when client sources their own fittings.
Safer = better, but comes at a price.
But there is still the issue of dealing with the heat coming off the lights. Even with fire rated items, if they are covered over with 18inches of insulation, they are going to get mighty hot. Bulb failure and overheating problems are still going to occur.
I quite like the look of these support boxes Click GB440 Insulation Support Boxes 400mm [GB440] - £5.66 and about to order some for a job. Apparantly once installed they can be covered over with insulation. Anyone used them..?
Courtesy of the link to the Iet
However, in situations where downlighters are installed in ceilings under roof spaces, where debris or thermal insulation may accumulate on top of the luminaire, a case could be made for building a plasterboard or metal box around the luminaire or installing a fire hood.
Leave Bill and Bens flower pots alone
Pinch the builders plasterboard instead,its cheap, effective, and if he is a half decent builder he will make them for you
101 potty postamations
and a silly amount of plant posts in the attic to trip over.
Grab ya old bike / TV / snooker table / BS7671 etc - fly up th loft for a part-y-P trip on a plant pot and put your leg through the ceiling and say I've been down the morgue like Vivian off the Young Ones if you can remember it look at chapter 12.:D:D:D:D
Maybe it was a good idea to put them there, but in all cases its most likely not.....
in accordance to P91
Plant Pot Brigade!
Australia
andrew692003,
Spudnik,
