Guest viewing is limited
A
andrew692003
Does anyone want to join? :)
As I've stated before I have never used these between floors or in any new builds so don't get out the sniper rifles straight away! ;)
The only time I have used clay pots has been in lofts where access isn't a problem and usually in older dwelling houses. Now, the last time I did this was a good couple of years ago not that that matters as I can't see a problem with it.
When fitting the pots I always make sure that the insulation is clear of the hole and all dust etc has been cleaned away then I fit the pot with the transformer outside lying on top of the insulation. I always push the insulation up against the pot which makes it very steady.
At the end of the day all you are trying to achieve is to stop debris falling on the lamp and letting the heat dissipitate to possibly stop causing fire so, does it matter whether you use a firehood, plasterboard box or a bloody clay plant pot?
Firehoods can be expensive and a PIA to fit, Plasterboard boxes take time to build and even the cheapest Firerated fittings can still up the cost considerabaly.
Cheers
You must have large loft hatches around your parts!
Most I come across are just about big enough to climb through, never mind take a mountain bike through.
They take wheels off and store them in flight bags and often buy a new one every year and cant let go of the old ones. :cool:
Hey, not at all. good points.
My points not aimed directly at you or anyone really.
just my thoughts.
Entertaining and interesting really:D
What debris are you classifying to be reasonably expected? What if lets say a cot or a bike or a old TV falls on the clay pot.....Hmmm....It smashes... maybe...probably...
Are these thing reasonably expected to be stored in a loft or will you tell the home owner, your customer, different.
At least the metal or plasterboard ones will flatten to a point and still stay in tact to a degree too and still provide protection a clay pot on the other hand will shatter in to bits.
When the customer rings you up and said your work has broken because something fell on it, what are you going to say...well you chose to have downlighters not me...he/she replies... you installed them and the silly pots...Didn't you think of that...itn't electrical work regulated...well those clay pot are not electrical...well your an electrician and you put them there....blah...blahhh.blahhhhh!!! ya..my...and the ...leg off...
What if they don't even notice the pot is in bits under or masked by the insulation. what if the pot damages the cable when broken.. then you would have caused the fire because you put them there...
Whoops, smash, burn away. Safety is no Accident!:confused:
Its not about saving the loft its about saving lives
I.e. escape time...................
Do all your clay pots ring? You know like the antique guys do the ring test...
God knows how many times I've bought clay pots for the garden and they have broke just from picking them up or filling them.
HAHA! You do have a point but the handle is in't turning....yet!
I think if something in the loft fell hitting the Clay pot or that metal hood the customer may be more worried with the bike handle portruding through the sealing!
Tell you what Marty, go to your local garden merchant buy a pot and start jumping on it! See how long it takes to break! ;)
Cheers
Haha! I've just read pages 3 to 4 as I had no time last night, I've actually been **** myself laughing! A lot of good pots sorry, points raised. As far as I'm concerned this is all light hearted fun and yes it probably has run its course and I'll carry on using clay pots!
ps someone mentioned pots between floor joists, I don't think this is a good idea and hence a firerated downlighter would be used.
Cheers
Cheers
Cheers
Yes indeed hilarious, entertaining and interesting too.
Why don't they install the spare TV in the ceiling to watch TV lying in bed?
There would be a good chance it ends up that way anyway. lol
oh, if the bike handle came through the ceiling at least my installation would still be in tact. lol
Great fun!
I have actually seen a full size snooker table in an attic. Christ knows how they got it up there, but once they did it sort of got 'jammed' in an immovable position at a jaunty angle. I told him he would have to get it moved or have surface mounted mini trunking. Saw a van with tzorztczki or something written on it outside his gaff later on, wonder if our not-too-distant cousins managed to traverse the billiard ledge.......
It is a load of bull about these down lighters being enclosed,if you enclose them ie in a can type down lighter all you are doing is trapping the heat in and thus you have created a minature oven where the heat cant escape thus makeing it more dangerous as if they were left uncovered and heat allowed to disperse.
I propose that within the loft space in conjunction with a fire hood, we also box in, put a flower pot on top with a fan assisted vent tube out through the roof.:rolleyes:
For the safety of the snooker playing trick cyclist; who's balancing the tv in one hand & reading his stack of ---- in the other, we should also mark out a suitable route through his downlighters. Maybe channel 4 could televise this as a celebrity challenge; something like 'My roof's on fire, but I'm OK because I have smoke hoods' (Just a working title at the moment):D
Plant Pot Brigade!
Australia
andrew692003,
Spudnik,
