Plumbers are great!!! | Page 6 | on ElectriciansForums
Discuss Plumbers are great!!! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Today I was in a customers house. I had to take up some chipboard flooring in the bathroom. I set the circular saw so that it will cut to the right depth and not too deep.... I think some of you have already guessed where this is going :D .... and start cutting.
Now in the five years I have been working as a domestic installer I have never had an accident because I plan, I'm slow because I plan, but that's ok because I don't have accidents.... until today.
Anyway, I start cutting and suddenly water starts spurting up into my face, it's a hot day but I fail to enjoy the cool water covering my head. I panic, there's no way to get to the pipe as the boards are down. I nearly always work alone, but for some reason this time a plumber was working in the house at the same time. He was actually in the bathroom with me at the time! He sprung into action, fitted some pipe to a downstairs radiator to drain it, during which time I'd got the boards up (looking horrified at the lake of water) and stuck my thumb on the tiny hole.
I absolutely sxxx myself!!!
The outcome was a small amount of water coming through the ceiling which dried and that was about it. The client was cool about it and the plumber fixed the pipe refusing any kind of payment. If he hadn't have been there I could have been in a whole heap of trouble and my PL insurance would have had its first outing!
So.... I'm ready for abuse but I stand by my claim, plumbers are great! :D
I guess that the extra money buys you 'that lip' that will give the floor the strength to be stood on again - clever chaps and good design but they own it (and us!)
what you need to be wary of, of course, is wet-pants's pipes tight under the flooring. my method is to drill a pilot hole carefully off centre of where you want the larger hole to be, enlarge pilot hole enough to get a boroscope in. search for pipes with said boroscope, then if all clear, a 4" hole. and as midwest's post. refit the cut out piece on a batten, using screws so it's re-enterable.
If you're going to buy one of these cutters @ChrisElectrical88 don't go cheap.
I bought the silverline one from Toolstation to save pennies. The plugs were about 4mm smaller diameter than the hole so they rattled about, and were about 3mm lower down that the board surface. I took it back.
My mate bought the Armeg version in a kit and it is spot on.
The plugs should be about ÂŁ2 each
Be aware that there are 2 sizes, 111mm and 127mm
This is a decent price for the 111mm set.
Armeg SBC111SET Carbide Solid Board Cutter Set 111mm, SBC111SET - http://www.discount-electrical.co.uk/product.php/391318333/armeg-sbc111set-carbide-solid-board-cutter-set-111mm
Reply to Plumbers are great!!! in the UK Electrical Forum area at ElectriciansForums.net
People who claim to be plumbers... and tilers... New bath fitted and the drain is accessible from the side and there are isolating valves on the...
C
Noisy main cold water pipe, my plumber hasn't heard this before. Hi Folks, Would like to cast the net far and wide to try and get some resolution...
ComfortablyNumb
C
