POLL - Neutrals at switches | Page 5 | on ElectriciansForums
Discuss POLL - Neutrals at switches in the Australia area at ElectriciansForums.net
RWJ
East Anglia
As the title suggests
In respect to the debate in this thread http://www.electriciansforums.net/e...electrical-forum/33420-neutrals-switches.html
I've decided to launch a poll to gage response from the forum.
GOOD / ACCEPTABLE - If you think Neutrals at switches is OK
BAD
/ UNACCEPTABLE- If you think Neutrals at switches is NOT OK / WRONG
UNDECIDED - If you have no preference or are fence sitting (like me)
The poll is timed for 7 days...... So get polling
[ElectriciansForums.net] POLL - Neutrals at switches
"as you can clearly see the neutral blues are in a massive lead and don't have to form a coalition with the cpc's to gain a majority win".
I never saw them done any other way with my old firm. I thought it was fine except on numerous occasions I saw 35mm backboxes having the following cables:
Feed in
Feed out
Lights switch line
Shaver
Fan isolater
"This light switch won't screw back, I guess you're going to tell me I'm doing something wrong now."
As a wiring method though, it seems more logical and much easier than three plate.
If im on a rewire and the customer wants 10 downlighters in the kitchen i prefer to take the neutrals to the switch using a deeper box. If its standard pendants I would just take the loops straight to the pendant.
Its a big fat GOOD from me...do it all the time for spot or wall lights!!!!. almost as good as a 4mm2, 32amp radial circuit instead of a ring final............now there is another can of worms popped open..
Remember a job where the client wanted some Futronix dimmers fitting, most needed their own format backbox and neutrals. managed easy on top floor by poking at the cable capping and sliding a neutral down but i remember one room i had to chase about 5M just for a little cable... and my chisel was blunt, what a mess.
I think it the best way due to not having to work on ladders when 2nd fixing so is a little quicker and easier, although the one time i didnt like it when i had a 4 way switch which had 3 2way circuits loop in loop out (3 x 1.5mm 3core, 6 x 1.5mm T&E) although it wasnt bad just took a while to dress correctly it was more the earths that caused the problem lol
Reply to POLL - Neutrals at switches in the Australia area at ElectriciansForums.net
