Preferred GU10 fitting? | Page 3 | on ElectriciansForums
Discuss Preferred GU10 fitting? in the Electrical Tools and Products area at ElectriciansForums.net
No adjustable option but most people never tilt their adjustables anyway!
I usually go for tiltables, not only because I think they look a little better, with the concentric ring around the lamp, but mainly because they generally require a bigger cut out, one that I can get my hand through and up into the void.
Although not a fan of tiltables (unless in genuine need), I do agree that bigger downlights look more generous. I've personally gone for ≈60 JCC Fireguard XL anti-glare white IP65. Wrongly ordered the standard size initially but then canceled the order lol
Amen. Worked that pretty promptly. 20 yr life my butthole. Downlights are the most unreliable LEDs IME - maybe due to concentration of light (& therefore heat) compared to panels or strips.
Evofires are my go to, super slim bezel looks like an integrated anyway, open back for lamp life. Ok you have to pull the whole thing out to change lamp so maybe use something else on a really cruddy ceiling. No adjustable option but most people never tilt their adjustables anyway!
There is now an adjustable option available, though only IP20 rated unlike all other Evofire products.
Reply to Preferred GU10 fitting? in the Electrical Tools and Products area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
