Yes. All cables are t&e, 2.5mm2, and same brand.Are all the cables the same size (csa) and type?
Discuss Problem with adding a spur to a socket in the DIY Electrical Advice area at ElectriciansForums.net
It's a Tenby socket. They are no longer manufactured, although you can find them on eBay.Is this a Crabtree Socket? For some reason they love to make their terminals nice n snug. Never had a problem with fitting three cores into a MK.
that reinforces previous post to double over the end of the spur cable,The terminal is too wide. All the conductors lie flat at the bottom, so the ones at the side are not clamped down tightly.
Yes, I'll try that. Thanksthat reinforces previous post to double over the end of the spur cable,
Thanks for the suggestion!I'd double them all over if there's that much room.
Reply to Problem with adding a spur to a socket in the DIY Electrical Advice area at ElectriciansForums.net
