Pulling main cut out fuse | on ElectriciansForums
Discuss Pulling main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
South Wales
I am aware this topic has been raised before, however, I was at a job this week where a new consumer unit is to be fitted.
I have asked the owner to contact the supplier to arrange for an isolator to be added between the old board and the meter.
On doing so, The supplier has stated the rules had changed and the electrician can cut the tag and remove the fuse to isolate.
Needless to say, I am far from happy with this so asked the owner to call them again. This time they said when I am at the job to call them and speak to them for authority. Again, I am stilk not happy and am presently refusing to do the job without a fitted isolator.
My understanding is WPD are the owner and only they should be doing such things.
Does anyone have any thoughts or heard anything to the contrary?
SSE told me,over the phone admittedly, that as long as you are registered with a scheme you can pull the fuse and let them know afterwards.....
That might be because for every job you are supposed to do a risk assessment/method statement and as a scheme member that's what you are expected (in theory) be doing.
Reply to Pulling main cut out fuse in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
yeah so it looks like an old off peak heating circuit to what would have been storage heaters my preference is to remove them completely from the...
