Pulling the Main Fuse (Poll) | Page 5 | on ElectriciansForums
Discuss Pulling the Main Fuse (Poll) in the UK Electrical Forum area at ElectriciansForums.net
H
hightower
So, anonymous poll - who pulls the main fuse when required (ie CU change) and who get's the DNO/supplier/whoever in to sort it?
Funny that down under the spark fits the meter and installs the service cable and connect it live to the over heads or onto the under ground service as long as you have the licenses.But any spark can pull the service fuse.That why all the sparks drive round with fiberglass ladders on there vans.
Done five years down there went it went ---- up here in 2007. Couldn't bring myself to drop my prices. Banks hate them.
They do have inspectors that check your first five jobs from energy Australia or country energy and then as long as your standards are good, its every now and then.
The license setup works well but there's lots of cowboys out there in the city's it's good work and new stuff is checked well.Any thing over 15/20 old is well hairy stuff.
Hey Guy's,
I do alot of DNO work, LV live jointing ,OHL's, service head installs etc. I know it's a pain when your changing a dis board and the supplier never installed an isolator for you to turn power out. Bottom line is you should contact the supplier to arrange with DNO to come out and pull fuse from head or install a secondary cut out for you. I have never heard of a DNO letting an electrician pull one of their fuses. I carry out work on UKPN,SSE,WPD,NPG,SCOTTISH POWER networks and they wouldn't allow you. To put things into perspective when I'm working with DNO gear I have to wear Flame retardant overalls/Flash proof, safety glasses/face shield, Lv gloves with over leather gauntlets. I'm not scare mongering at all here guys (not my style) however these supplies aren't backed up by a fancy rcd and I have seen first hand the results when stuff go's wrong. Just be patient, putting a job back a couple of weeks is better than hurting yourself.
https://www.ssepd.co.uk/Connections/usefuldocuments/
Scroll down to 'Electrical contractors'.
Having just re-read the document, I see that it only applies if you are a member of NIC/SELECT/ECA/ELECSA/NAPIT, or it's an emergency.
Hey Guy's,
Scottish and Southern Energy Power Distribution do have a procedure for electricians to, in certain circumstances and with control systems in place, remove and reseal a cut out fuse.
This is dependent on the assurance by NICIEC, ECA, ELECSA, NAPIT, SELECT that their members are competent.
Hey Guy's,
found this once, and that was AFTER cutting the seals.
[ElectriciansForums.net] Pulling the Main Fuse (Poll)
Hey guys,
Good document, I stand corrected on the SSE front. I shall ask the auditors from the other networks I mentioned on my travels about electrical contractor's pulling their fuses.
Hey Adie,
That fuse is ok, it's these ones you've gotta watch out for o_O
Reply to Pulling the Main Fuse (Poll) in the UK Electrical Forum area at ElectriciansForums.net
sounds like one of those jobs to swerve and let it be someone else's problem
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
