RDB85
Trainee
I’m looking to buy some PVC Conduit for some security lights rather than clip the cable. We don’t use it in work. But I know I need 20mm conduit but would I be okay using 20mm inspection elbows? I assume they just fit inside?
Rigid Non-Metallic (PVC) Conduit – preferred for cases where wiring is run just beneath the surface of concrete walls or flooring. It’s primarily chosen because it will keep water that may seep through the wall from the wiring.
RDB85
Trainee
Liverpool
United Kingdom
Trainee Electrician
PVC Conduit Question
RDB85,
timhoward,
