What siz conduit have you bought?
I would be using 25mm for 10.0 T&E.
Could run into difficulties trying to run 10mm2 through 20mm conduit20mm White PVC conduit.
You will find it nigh impossible to pull a 10.0 T&E through that.
Will it be a straight conduit run? how long is the run? sorry my bad you have already said. Still think you may have problems, getting the cable down that conduit.As I say it’s hard to take it back given the circumstances. My uncle did say 20mm would be fine when I asked him.
Single core cables may be your answer, not T&E.
Any answer for post #78?
Ah right, so there is no requirement for armoured cable now then. Fair enough.
32A MCB with 1.5mm cable - they were optimistic with that eh.
