C
Crosswire
What on earth is the difference?
Discuss PVC SWA vs XPLE SWA? in the UK Electrical Forum area at ElectriciansForums.net
One has to remember tho that 90 degree cable should be matched with gear
Or you could just order the right stuff from the wholesalerTip of the day. To test if sheath is xlpe or PVC drop a piece in water. Xlpe floats and PVC sinks.
what are some typical examples of when you would use XPLE over PVC please
would it be in areas with a greater ambient temp for instance???
I think you mean the ''Insulation'' not the sheath. As the sheath is PVC on both XLPE and PVC insulated SWA cables mechelec...
Whats the best way of telling difference in existing installation, such as filling out a cert etc? I spent a few times trying to work out if a cable is PVC or XPLE?
Reply to PVC SWA vs XPLE SWA? in the UK Electrical Forum area at ElectriciansForums.net
