R2 test on a ring main where the conduit is the earth | on ElectriciansForums
Discuss R2 test on a ring main where the conduit is the earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
K
Kev2632
What readings would expect for the wandering lead method whilst testing from the consumer unit to the sockets, would you expect in the region of less than 0.10 ohm?
yea its a ring final but the conduit is the CPC and once ive deducted the resistance of the "wandering lead" im getting less than 0.10 ohm for the resistance of the conduit, does that sound right?
What cable is used? Is it a RFC or a radial? whereabouts are you expecting to get this <0.1 ohm reading and why mate?
see his thread from yesterday for the whole story and this will all become clear.
He needs to find a fault in a circuit with high loop impedance where conduit is the earth.
so from yesterday, we can deduce that the fault is on the live or R1 part of the circuit giving you greater than 200 ohms overall.
yea when i moved onto the Ringmain im getting less than 0.10ohm for the R2 reading on the ringmain circuit does that seem to be right ?yea
you didn't mention yesterday it was a ring final. Have you taken all the socket fronts off?
im on a different circuit than yesterday and all im wanting to do is get my R2 reading for the ringmain and im getting less than 0.10ohm for the ringmain does that sound right? its a 1 storey 1 bedroom house really small.
i'l chance it and say yeah, sounds about right. You're spending some time testing this house!
yea thats what i was thinking ye, you always expect really low readings like that yea, with a small house and when testing for the R2 reading yea??? nahh ive been busy with other jobs and that this last two days, only got a wee while here and there at it like.
yea, well let me take a pull of this here spliff while i think, nahh, bad weed, poor joint somewhere.
Reply to R2 test on a ring main where the conduit is the earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
