RCCB as main switch? | Page 2 | on ElectriciansForums
Discuss RCCB as main switch? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
I have been to a property where the tails come out of the meter and into an RCCB which then feeds the main switch of the consumer unit. All circuits are protected by MCBs.
If I'm adding a new circuit, is it best put in an RCBO instead of an MCB?
Should this question not be on the Screwfix forum ?
You would use a MCB. But do you know why ?
I would use an MCB as I believe there would be a level of RCD protection.
Obviously not the best situation as it would take out the whole consumer unit.
I've also read the affects of having an RCBO and RCD/RCCB together.
If I'm wrong, could you please explain?
Much appreciated
Much appreciated
ideally, you'd upgrade the board to give circuit division between 2 RCDs or, better still, RCBOs. but you can only do as much as the customer is prepared to pay. in this case, a MCB for the new circuit is the most cost effective solution.
Much appreciated
Your thinking along the correct lines. We're guessing to some degree as we don't know all the details but it seems ok.....if operation is satisfactory
It will have a 'S' in a square.
But it if this is installed this will not give your circuit appropriate RCD protection.
whole DB change is what I would recommend.
Thank you.
So if the customer would not pay for that, and it was a time delayed rccb, could a new circuit not have an rcbo so it is protected?
Reply to RCCB as main switch? in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
